apologies to traction tyres... rear suspension just hasnt got that much rear camber to give. plus needs a roll.
will hunt down some Z33 camber kits and fingers crossed they'll fit :unsure: thats what the 'muricans say they use
The statistics aren't accurate for reasons I raised in my post
It's not foreign ownership when the purchaser is a resident
You'd need statistics on ethnicity of home buyers and multiple home buyers, but can't do that for obvious reasons
How many people do you think are trusting friends or family with hundreds of thousands possibly millions of dollars to get a house to get around laws? Not many Id imagine especially since they can apply to the foreign investment review board for permission
well the whole point for the $5000 fee for international investors is to fund investigations into purchases which were cutting corners/illegal.
"The higher application fees and penalties are expected to fund an improved enforcement of the current foreign investment rules.
"We need to make sure that all foreign investors are following the rules, and that those foreign investors who break the rules are not able to profit from breaking the law," the Prime Minister, Tony Abbott, said in launching the paper."
http://news.domain.com.au/domain/real-estate-news/foreign-buyers-set-to-be-hit-with-steep-fees-to-buy-australian-property-20150225-13ob2a.html
I hear Ya man but being in the industry and having contacts all over im gonna go with the info im getting from people on the front line it's a non issue - just a popular policy for the 'battlers' / art students who took gap years and fkd around through their 20s and wanna blame someone for the fact they can't afford a house.
Heaps. That's like saying why are there boat people when they can just wait in line for immigration. The figures don't add up when I hear of so many auctions being dominated by the Chinese - and I'm expected to believe that only a billion or so dollars traded hands from foreign investors = only ~2000 or so homes Australia wide?
They don't trust their own government or banks / local investments so send over here instead. Australian property market is the new Swiss bank account.
Just cos they look chinese doesn't make them a foreigner man, plenty of 2nd, 3rd, 4th generation permanent residents just as entitled to buy as you are.
Well if im having difficulty on a FIFO professional income, I'd hate to imagine how art students would have any chance...
  • Like 1
Guest
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
