Just cos they look chinese doesn't make them a foreigner man, plenty of 2nd, 3rd, 4th generation permanent residents just as entitled to buy as you are.
When they're buying on behalf of foreign investors, no, fark em. And I don't want a single race city and inner suburbs, it's boring and crap. I like the variety that we had / kind of still have for now. Your kids will be lucky to afford Melton the way things are going.
An engineering degree in a service-driven country.
You may as well have studied Arts
lots of positions requiring engineering.
theres just a lot of engineers around. and also positions that dont vacate often. most engineers i know get shoe-horned into project management roles within the company they started.
It's ok I'll give em one of mine
Yes there is a lot of asians, come west heaps of indians too Australia's a small population.
You've got one example it's hardly solid ground the statistics on foreign ownership in aus are actually very low
It's a media beat up playing on Australia's underlying racism. I'm not even backing them up as if I make money out of it cos I sell established houses and I need to shift 10 or more for it to be $5 mill worth lol
Are you kidding me? I go into Burwood One nowadays and every FIFTH person is an older white Australian. Three of them are obviously chinese, none speaking english, and the remaining one is usually either another asian nationality, european or south american. I know the numbers on your board don't say that Chinese are taking over property, but lets not pretend like the population hasn't significantly blown up from what it was 5+ years ago.
  • Like 1
Nobody denied the population has increased but who says they've bought property illegitimately - which is the topic of conversation.
Who knows really, nobody really has a source of Legitimate Illegitimate Purchases numbers hey? Our richest customer is a chinese real estate agent here in Melbourne, wonder how!
Got heaps to contribute on this point but bound by secrecy so will just comment on the pic of me and Birds...
Damn we're fkn chiselled
Same lol... (apart from the chiseled bit)
Do you and Hamish, speaking from your own opinion & not representing any entity agree or disagree with the following points made.
/corporate communication policy
You kinda insinuated it
If I paint myself with a bad brush and assume the worst of myself, I can interpret what I said that way sure. It's a stretch but I can see what you're getting at.
What I WAS getting at was, while you say that the chinese are doing everything legitimately and it's all a media blow-up. I'm saying our richest customer being a Chinese real estate agent is telling of how many are suddenly showing up and buying property, regardless of legitimacy.
Maybe I should start learning Chinese and open up a Chinese bank in the land down under, can't you hear the thunder guys?
Hook a brother up!
#amserious
So now your accusing of him not only buying illegally but working illegally to? Are only white people allowed to make money and buy property in aus?
Hamish's mate had a bit of trouble getting hold of one...he must have been sending emails to the wong address.
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
