CS 1.6 is where it's at!
I remember a few years ago it was supposed to do a fly-over of St Kilda yacht club area from Point Cook. few hundred people rocked up to the wave break pier thing and waited for like 2 hours. finally a tweet spread that they couldnt get it ready in time...
I was there that day.... 40mins saw a post on fb from RAAF with the cancel. Was very disappointed..
am down for LAN.
simons house sitting house is volunteering
I would say yes, but they're getting back on Monday and don't want it smelling like VWL
Tony writing cheques his clients can't cash
That's what borrowing from the trust accounts is for
Well it did say it was a flypast but didn't think it'd be so literal flew by slowly and that was it.. Was very underwhelming!
The others at least do something but eh still a good day. Shame the f22s are static display only too
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
