I catch the train to work, so my only drives are on the weekend for fun, and some errands during the week
Two cars would just be silly
Guess the beamer's gotta go then
On a side note, I never appreciated my car more than when I had Alvin's auto as a daily driver. Daily and weekender is the way to go. You try to combine both and you're taking your compromise work chariot out for weekends = not the same.
f**k that combine all the way.
And by combine, i mean be a man and deal with the uncomfortableness.
I had 6/8 coils slammed and wound all the way up, solid bushes and mounts, bride bucket that was on the floor with high bolster than squashed my balls, 330mm wheel with a 50mm spacer, a tripple heavy duty single playe button clutch and nismo diff.
I LOVED driving that thing as a daily. The ONLY drawback was police attention. The way it handled made even a short drive at the speed limit fun.
Yeah I thought up to 30% less would be pretty normal, but the problem was I was only getting 300-350kms to a full tank on a standard ecu with 100 octane, wasn't very impressed with that.
well the stock tune is overly rich and that's really all you will get from anything other than highway driving anyway
Birds I know E85 wasn't made for Economy, but what kind of mileage are you getting around town for a full tank?
I'm not the best example for economy simply because I race a lot / enjoy my car, and 80km/h is 4th gear territory for me (always like to have power on tap).
So with that said, my daily driving is 17-18L/100km on E85. I fill up with about 52 litres (~$60 thanks to United's rip off pricing now) and that's usually just shy of 300km.
Mind you, my fuel economy before that wasn't fantastic...about 400km to a tank on 98, with a pretty rich tune. I used to get 450 on the standard ECU with fresh O2 sensors.
Have you changed them in your car? They make a hell of a difference if they are worn and you're running a closed loop tune.
Guest
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
