I would of thought more than 6
Really needs to show as a percentage, bringing Number of registered Bikes vs registered Cars into the mix
Also spotted that the Age Groups showing that deaths of P-Platers aren't that high compared to older age groups... Even once you realise they're showing the Tabular Data using uneven segment sizes (older age brackets are a 10 year span, where there's three brackets from 18-29)
Out of the millions of drivers on the road, that's the road toll and we devote millions of dollars towards safety campaigns when a road toll is always going to happen :/
State and local government = excuse to keep people in a job
mate took on a new apprentice.
he was telling me how dumb the kid is.
i didnt believe it untill he said aye moh watch this.
calls the kid over and asks him to fax a sheet of paper.
kid asks how?
mate shows him, he leads him into the paint room, places the paper on the scale and turns on the paint shaker.
the kid stands there staring at the paper for a few seconds, shaker going crazy behind him.
mate turns it off and says. done. its sent.
by now im expecting the kid to crack up laughing.
no.
he said thanks and asked what else he can fax
flamin mongrel actually believes you can fax from a paint scale.
how did this kid make it to 18?
  • Like 1
kid asks how?
no.
Lol it's the next generation.
Kids are growing up using technology without knowing how it works or gone through the struggle to make it work.
You think any next generation would go through the headache Dezz did with his laptop? To understand what was wrong and how to fix it etc.
As long as someone tells them how to use it that's all that matters lol
Drove the skyline to racepace this morning from my parents house, my dad followed in the evo, then I dropped him at a train station and drove to work...
Somehow, he gutter rashed my black wheels against the curb within 10m of getting into the car... *sigh* So they've got a bright alloy strip that goes 1/4 of the way around the wheel :| Get. f**ked.
Guest
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
