I like these:
http://www.importmonster.com.au/shop/product_info.php?cPath=40_45&products_id=1899
What's the price look like for you guys, what would you pay..?
Also.. Is it possible to shave a couple of mm off a wheel to make it a few mm higher in offset?.. Sounds dodgey but dem rears will poke out hard and I want to run big tyres.
Edited by UNR33L
Dude with a gun & no will to live has no relevance to a billionaires life
But sometimes a lot of relevance to his death
http://www.dailyfinance.com/2010/06/22/bad-fortune-five-bizarre-billionaire-murders/
I like these:
Hamish will tell you to harden the fk up, particularly as they are professors
i was considering shaving off offset... bad idea. you're not shaving off offset, you're removing meat that sits on the hub/wheel studs.
just roll guards/sort out suspension, fit tyres that fit etc. you'll be fine
I like these:
Harden the fk up
Especially as they are professors
D1Rs come in all sizes and offsets
Yeah but only one magnitude of gay
Lee even like 2-4mm would f**k it you think?
Birds d1rs in 20s look sheit!
Lol
Sif 2-4mm will make a difference fgt
That will get you 1 tyre size up which you will never notice.
4mm would be acheived with a guard roller and about 2.3 seconds
Lol.
Aaron has already rolled them for me, maybe I'll go down to import monster one day and try them on..
You had professors? thought you were rocking varrstoens
I want to at least fit some 265s f**k those 225s and 235s what am I gonna do with those lol
Edited by UNR33L
Engine build complete after many dramas.
'greg can you come here and tune the start'
Rock up with laptop
Play with ECU
car starts... and appears to run/idle fine/way smoother than it did before it died, no smoke, no leaks, just... purring away
f**k, expect 7 years of bad luck now everyone
I'm sorry
D1Rs birds?
11025186_690767431046669_180923112286857
That actually looks pretty tough.
People may diss them, but they are lightweight, cheap and can take a beating. Break or rash one and $250 to replace.
Lol.
You want to shave 2-4mm
Thats going to be the difference between a 255 and a 265.
Or a 235 and a 245
Etc etc etc
What on earth makes you think shaving 2-4mm will allow an extra 20mm?
Guest
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
