guys, sometimes i dont understand how f**king stupid some people can be.
im in the office doing some quotes, all the doors are closed, gates are locked shut.
dude just rocked up.
called the lane line- no answer, called me, no answer. then tried to push the gate open.....
omg this shit makes my hair hurt.
You sure that wasn't your mate looking for a place to stash all his profits
Nismo 555s checking in with 2 years of pump E85 usage and not a single blocked injector was had that day
are they top feeds?
(or am i coming from the SR world where side-feed is normal and top-feed is like the injector master race that is not always attainable)
are they top feeds?
Side feed
Converting to top feed is like wearing a mini skirt
You're asking to get raped
Come at me feminists
Miguele and I finished throwing my turbo back on last night / today (and swapped his subi turbo for a better one)... My baby lives!!! Idles like a boss again :) Only issue is I snapped a bolt (1 of 3) that holds the turbo elbow on so will need to source a replacement for that (and hope it's not snapped down too low to grab it with some vice grips).
Then Sandown and BOOOOOOOSSSSSTTTTT!!!!
I'd be replacing all your rubber fuel lines Tony. I know people say they don't break down, but you've got black "goo" in your injectors. So it's either rubber, or some sort of molecule that came from the fuel. Better to be safe than sorry seeing as biofuel hose is cheap.
Well this is what i found on an analysis from another forum. I made a thread in the forced induction section.
Hi,
I don't post often on this particular forum but I just came across this thread and the other one in the alternative fuel section. I am an engineer, and I have been following industry developments in alternative fuels.
I doubt many of you are aware of this, but GM had a production port injected turbo flex fuel engine all the way back in 2007. It was a Saab variant of the Ecotec engine family. Saab did extensive testing on a lot of boosted E85/Flex fuel issues and published some work on it. See Bergstrom, "The New ECOTEC Turbo BioPower Engine from GM Powertrain," 2007 and Bergstrom, "Alcohol Based Combustion Engines - Challenges and Opportunities," 2007. Deposit formation is one of the dirty little secrets of E85; another is pre-ignition.
GM found the exact deposit problems many of you are experiencing. I have read a lot of different ideas on here about the nature of the problem and I have read a lot of speculation about solutions for it. Here is what we know for sure about the deposit issue, based on GM's internal research.
Chemical Origins of the Deposits
The deposits primarily consist of "Poly Iso Butylene," or PIB, a cleaning additive in the gasoline portion of commercial E85 blends. As far as we know, the ethanol itself doesn't directly cause this type of problem with injector and valve deposits. This PIB additive was never designed for use in high ethanol concentrations.
PIB is designed to soften engine deposits, but below a certain concentration (by total fuel volume) it is actually counter-productive. What happens is that with insufficient PIB by volume, the normal valve deposits don't soften. The PIB actually combines with these normally occurring deposits and makes build up worse.
Running PIB-free E85 is basically impossible in a practical sense. GM engineers ordered special batches of PIB-free E85, but in the real world the E85 still becomes contaminated with PIB because the entire fuel refining and transport infrastructure has traces of it. Still, with this very low PIB concentration E85 deposits can still occur at similar rates.
A lot of people on here have speculated something along these lines.
Effect of Drive Cycle
Deposit formation is highly dependent on vehicle use and overall drive cycle. This whole issues is complicated, but aside from the makeup of the actual E85 blend, drive cycle is the #1 factor in these deposits.
Bergstrom, "The New ECOTEC Turbo BioPower Engine from GM Powertrain," 2007, Internationales Wiener Motorensymposium 2007, p. 29
On the left is a multi-hole type (not pintle type) fuel injector after 15,000 km running a GM in-house designed drive cycle to simulate major stop-and-go city driving. On the right is the same type of injector after 60,000km in a high-speed (mostly highway) drive cycle. Both engines were running the same commercial E85 blend in Sweden, consisting of 95 RON fuel and denatured ethanol.
Drive cycle variations may not explain absolutely everything but it is a reasonable hypothesis for why two vehicles running the same E85 blend can have such variability. This can also partly explain why somebody doing a lot of highway driving (rural driver or suburban commuter) who always runs E85 may never experience noticeable deposits.
Using Fuel additives and Normal Gasoline blends
There are a lot of fuel additive blends out there and they change all the time so I can't speak for all of the various formulations. What we do know based on GM's research is that PolyEther Amine or "PEA" , which can/used to be found in Techron products, cleans valve deposits but does not clean injectors with this problem. In fact, too much of fuel system cleaner could make the problem worse.
So how do we clean up the deposits if an engine is prone to them for whatever reason? Put "normal" gasoline blends in the tank and it will go away within 1 tank. You don't even need to pull the injectors.
Most of you already knew that. It's not really news; it just confirms with reliable sources what has been widely understood.
Conclusion
So yes, I didn't have any earth-shattering solutions to present, but I did clear up some of the mechanisms for this deposit formation. The deposits are caused by the gasoline portion of E85. The two biggest factors in deposit formation are the additive mix in the fuel and the way you drive the vehicle. Fuel system cleaner products are innocuous at best, counter-productive at worst. The type of injector or fuel system you run might matter some but they are not part of the mechanism of deposit formation.
So if you figure out that your engine is prone to these deposits, be mindful of stop-and-go traffic and put gasoline in your engine sometimes to clean it out.
Hope that helps.
Guest
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
