Had foxtel installed today....sound isn't coming out in 5.1 for some reason... Anyone know why?
foxtel box is connected to the receiver via HDMI cable, receiver is connected to the TV via HDMI... Don't see a reason why it shouldn't work as everything else connected to the receiver is in 5.1....
Make sure that your Foxtel Settings are set to output sound in the proper format for the receiver to accept (maybe AC3 or similar), also make sure that the receiver is set to do Virtual Surround if it does happen to only receive a 2.0 or 2.1 signal from foxtel.
  • Like 1
Haven't even looked into settings yet, just assumed it'd work by default like everything else.
I'll sus it out now
Audio options available are
SPDIF digital audio output - AC3/MPEG
SPDIF digital audio delay
SPDIF digital audio attenuation
HDMI digital output - AC3/MPEG
Guessing it's something to do with the first or last options, but I set them both to AC3 and both to MPEG and nothing changed audio wise
SPDIF is if you're connecting up to your receiver using an Optical Audio Cable
HDMI is obviously if you're connecting it with your HDMI cable, so choose that bad boy...
Then you switch to the receiver settings for that input source and make sure it is set to expand out to 5.1 surround if it's only receiving a basic 2.1 signal as an input. Often you can hit an info button on the reciever remote and it'll show you info about what kind of stream is coming from foxtel
I opened an on screen receiver menu, selected 'sound program' then chose 'SURROUND DECODER', instead of the 'STRAIGHT' it was set to.
Seems to be sending sound through all 5 speakers now, just not sure if it's sounding how it should sound...I'll keep playing around with the settings...
The majority of Foxtel is in 2.0 isn't it except for some of the HD channels if you're lucky.
Yeah looks like it... I've got the HD package so not sure how many channels aren't HD, but the receiver seemed to be able to output in 5.1 last night...
Pretty poor that it's not all 5.1 from foxtel
lol
Also while we are on MP's mannerism's, I was listening to JJJ on the way home (weird huh) and they were interviewing Dan Andrews...
What finishing school did he go to again?
  • Like 1
Only selected channels and programs play in 5.1 so the majority of the time it will be in stereo.
If you want to watch stuff with 5.1 sound just download it. It's cheaper and is generally better quality haha. One of the reasons I don't have Foxtel even though I can get it for nothing.
Guest
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
