Then I realised I can do these things :P
crown wheel bolts used by eleventy models so that's no good. HOWEVER half shafts are only shared with R34 RB25DET MT so there's your best bet for a bolt in diff centre.
seems like a lot of moolah for just a centre... when i would consider even a viscous diff to be an upgrade.
maybe when i need to get rid of a lot money quickly... and then ill also grab these to fill the wheels
http://www.tunerwarehouse.com.au/index.php/products/product/view/125/1405
odie's D2's looked good today. i'd want low dust brake pads though, EBC seem to do some for D2's but the EBC daily driver pads ive got now make a bit of dust
Lol, grab a 34 Viscous, shove a 38424-40F67 shim in there, call it good :P. R34 also came in torsen LSD too. I think Alvin has one kicking about?
whats the washer do? after seeing Charles' torsen diff in action i dont really want one :P
sub 1:30 is solid time, especially for sub 200kw cars (except for 86's on semi slicks)
Guest
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
