Well with the shitty exchange rate these days savings wont be as much but should still be cheaper. From memory my diamond from the states was over half the price compared to Aus
$15k for diamond? Baller!
My opinion is cut is the most important. It determines the 'brilliance' and sparkle
Clarity and colour. Just go for the best that the eye can see. Why pay for double for imperfections that you can only see under a micrscope at 100x zoom
Then just go for the biggest diamond lol
Make sure to inspect and get a report on the diamond, can get independant along with the GIA report to make sure its not dodgey
lol had an argument with a (Chinese!) colleague about clarity the other day...he maintained it was worthwhile cause if his wife is in a room with other women they'll be comparing diamonds and next to another diamond they'll see the difference in clarity...I said you need to find another woman
Thanks Ric...should have you round for a drink nohomo...did you notice the Versace decanter?
IMO trick is to buy grog too expensive to drink on the daily (am aware I have baileys and midori in there; it's a rule of thumb jack ass). And replace what you do take when you take it.
Haha do it fgt.. I did see the decanter, very nice
That's basically my strategy for keeping it stocked. My henny and patron don't get touched a lot. Been through more Tanqueray than I care to remember though
Will probably do another Dan Murphy's run soonish
Any connoisseur of the rare and exotic needs to visit Nick's wine merchants in Doncaster if you haven't already
In fact everyone should visit regardless, and even if you've already been there
mmm chartruese.
been off it for a while and then had some the other night with lemon cordial. made me remember why i used to rave on about decent spirits. had a few too many beers over the course of last week and felt like crap overall. will make the change.
i need me a decent cocktail making set and some whiskey glasses (im not into whiskey, its for the new front table in the gloria) do versace sell whiskey glasses?
I cracked open a 6 year old bottle of chartreuse 110 the other day
Surprisingly smoother than I remember it...either my tastebuds and throat have changed or that drink got smoother with time, which it really shouldn't given the content
You're damn right they do son
Thick bottomed ones with the Medusa head suspended in the middle
Almost pulled the trigger on them when I bought the vase
You got older
Your taste buds died a little
Your whole body is dying
We are all dying
Little by little
Every day
You got older
We are all dying
Little by little
Every day
This is what I explain to people when they turn their nose up at white wine and tell me when you're more "experienced" you'll have an appreciation for red over white
No mofo, you just lost your sweet tooth
  • Like 1
That's my decanter, thanks :)
f**kin lol, glad my missus loves diamond simulants just the same, and would be happy with a ring that costs 1-2 grand max.
Not entirely... If i drink white it's not that sweet shit. Never liked it.
Yeah but those people usually scoff at the thought of a dessert wine or a moscato
Pretty funny even cellar door people have bagged them out when they are selling the fkin stuff
Nothing wrong with a desert wine to accompany a desert.
The correct way to have dinner is:
While waiting for your table, Belvedere martini (franklin)
Upon besing seated and perusing the menu Draft beer or champagne if it's an occasion.
Order food and request a wine match for each course.
Drink beers in between courses to cleanse your pallate.
if desert, desert wine
If cheese, choose cheese and request wine match.
After desert XO Armagnac as a digestive.
Then elsewhere for scotch
The correct way to have dinner is however the f**k I want
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
