I really really want to know the hard numbers on how many people are actually intolerant to fructose, gluten, this and that, breathing unfiltered air, other peoples opinions or the colour green.
Seriously, its starting to feel like an epidemic of people allergic to all sorts of stupid shit.
I mean go back five years, had anyone even heard of being allergic or intolerant to fruit? fruit????
MOST (not all) is just to feel special
I could not tell you the amount of times customers claim to be gluten intolerant then order a flour FILLED dessert
haha you are describing my room mate that doesn't eat dairy or gluten but ice cream or dessert is ok ;)
don't think he has been tested.. just apparently feels more energetic not eating that stuff, fair enough.
between that and my gf (subtle) being vegetarian makes it shit for dinner options if I ever want to cook something
Edited by UNR33L
My vegetarian girlfriend cooks meat-based meals erry night
umad Leigh?
I don't live with mine, aint even mad
She cooks me bacon that about it (not touching my steaks!)
Edited by UNR33L
I'm some form of intolerant. Have been for about 8 or so years now.
I got tested for gluten and came back negative. If I eat bulk pasta, bread and potato I'll feel like crap for a couple days and if I drink more than a 6 pack it blocks me up for around a week.
I just try to avoid it and drink in moderation (when I have the will power).
she got a whole bunch of tests done after feeling consistently unwell, reguarly after eating certain things.
we went on a holiday and she was feeling like crap basically every night. she passed the gluten test, but proved intolerant to fructose. as with any intolerance it differs per person, but the most annoying foods to avoid for her are....
apples, pears, oranges, onion, garlic, avocado, ciders, foods with heavy fruit juice/concentrates, gluten-heavy foods (bread, cereal, pasta).
so basically a half-assed gluten-free diet with certain food removed. and we've slowly figured out whats ok (peas, beans, mushrooms and others in moderation) in small amounts. i cook with onion and garlic but remove them or she picks it out. none of its life-threatening stuff, its just avoiding being unwell. and taking medication after meals is a poor approach people take.
Fair enough would suck not being able to eat sweets!
Dat awks moment when she asks to move in with you and you can't give her an answer that won't offend the shit out of her
She said it was her or the steaks.... so he pulled up the anchor and sailed away #combomeme
  • Like 1
Did you order from Hamish a flour filled dessert doe?
so... "not being a phaggot" intolerant?
Lol, has been lightly discussed but she has a cat, I do not want a cat.
Guest
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
