How frowned upon is taking a few sickies in notice period? lol
Keeping in mind old and new workplace are somewhat affiliated.
if you going to, be sure to back it up with a med cert cause it sure looks planned/dodgy...
Never good to burn bridges when moving jobs.
I'd rather get stabbed in my sleep than stabbed in the real world
Dream people can't really hurt you
That's what people thought till Freddy Krueger killed them in their dreams
Frowned upon, if their dicks just do jack shit at work lol
Is the sick day going to be on Monday? When apparently doctors offices are expecting a 1000% increase in visitors coming in for doctors certificates because the government has robbed them of a public holiday?
Compulsory medical certificates for 'sick leave' is the biggest waste of time. Probably clogs up 50% of the doctors office
Should just take it whenever you want, i mean if you take excess its going to unpaid/annual leave anyway
Yeah I think if we take a Monday or Friday or 2 in a row we need a cert.
I've had to fill out a stat dec TWICE because apparently they didn't believe I was sick. Shows how good this place is.
Lol what a waste of time
Because an employee is suddenly going to fill it out and say hang on i wasn't sick you got me. And if you have to get it certified, the other person is really going to know that you were sick on that day....
Get tune, million of comical errors happen.
Then lucky, Osaka imports open, and have the part I need that I spent many hours yesterday trying to get around.
Ace!
Drive there, obtain parts, two infact.
Correct issue with MAP sensor, so car actually running on flex fuel.
So good!
Test traction control, as it's wet outside. Working so well. So effective.
Listening to new album from favourite band, rocking out hard. Life is good. Great start to the day!
Then suddenly, kids run out infront of car. 1m (or what seemed like it) away.
Panic-brake, pull wheel in direction of "not someone's f**king kids", rear end loses it, end up mounting the kerb and parking on the nature strip in a very uncontrolled fashion.
Get out, yell at kids until they're crying because f**k SAKE.
not even my wheel
ffs
Totally because Greg.
Probably a better driver may have managed to countersteer and avoid the kerb, but man, panic braking means very little went through my head.
Still better than putting someone else' head through my front bar.
+1 funnies because its a borrowed rim, which means mine is fine...
I think it's repairable. Just looks like a lot of gutter rash. I do mean a *lot*. It isn't buckled, so I mean hey that's good.. I guess..
Guess whos' booking an alignment, though!
Any pro tips re: Wheel fixers? I asked Alvin as he got my wheels I sold to him repaired and fixed and repainted but no reply because reasons.
Guest
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
