3.4l RB is the most I am aware of...
also a lot of the Ford guys running sub 11 Barra's are actually de-stroking to 3.6 / 3.7 odd due to vibration issues at high RPM
Destroking? What is this madness
Edge motorworks sounds promising
Call and Barry answers
Him: You vont stroker?
Me: Yeah that or an RB30 bottom end
Him: Yah 30 torque monsta...lots of power...do that
I like where this is going
Hahaha.
Barry has built a few engines for me, I've always had good experiences.
Be patient though.
Number is 0401300028 just in case you are still waiting for a PM.
Unrelated:
Today switched from 50,000km old KU31 235s on the front and nearly bald R1R 265s on the rear to AD08 255s and AD08R 265s respectively.
Wow what a transformation. Those tyres are unbelievably good value for the $220 each they cost me. So much corner grip it's ridiculous; just turns in so well with the 255s up front. And finally a set of road tyres that can hold my 2nd gear all the way through - time to break out the G-tech again Leigh :P
Mind you, those KU31 are an incredibly hard wearing tyre. Still 40% tread left on these. Awesome value for a daily driver not pushing too much power.
Also it's friggen handy living literally across the road from a tyre workshop. Cash tyre changes and alignments ftw - dude was trying to convince me to sign up to a drift event coming up lol
so your finally working out that those toyos were NOT great preformance tyres...
what next realise that D1R's are not great light weight rims.....
that said ordering some RS3s next wek ust to not be on the Yoko band wagon .. or mroe to the point as they don;t do discounts on 17's......
how the hell do you crack a fuel tank?
I honestly want to know, because I've split four tanks now.
Four!
From two different cars.
By now, I absolutely know the plumbing of the charcoal canister back to front.
You can't even find this shit on google. Seriously, look for "R34 cracked fuel tank" and behold the lack of .. anythings.
It's quite shit. Surely I have to be doing something wrong like pumping 30PSI into my fuel tank, but having checked the lines there's nothing there.
Looks like the crack is right up top though, so it only leaks when I'm at 100% fuel. It stops leaking and the gauge is still pinned to the top, so, gonna be filling up 75% until I buy a new tank from Nissan.
I've since disconnected the charcoal canister.
But seriously, ffs.
Birds my pain is real.
I'd assume your chassis is twisted due to all of the massive torques... hopefully its so twisted that a 33 tank will fit ;)
I'm just trying to get rid of it out of the garage, so take it and see, then it's your problem and not mine.
Looking at the pics here http://www.sau.com.au/forums/topic/444306-r33-gtr-and-r33-gtst-fuel-tanks-the-same/
Looks to be very similar, though I can't remember which side some of the hoses run to. I swear they may be different but there's no way to know until the thing is out of the car. Which really needs a hoist.
If only there was a guy with a hoist who does things on the cheap...............
Guest
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
