Simon 100% no passenger laps tomorrow? I wont bring my helmet then!
Dezz what company do you recommend for phillip island track days on the bike? thinking of taking the MV around.. fun times into turn one?
Phillip Island ride days are the only company that run them as far as I know...
first rule of BMW ownership:
get BMW cufflinks and wear them everyday
second rule of BMW ownership:
get the biggest OEM BMW wheels you can find (regardless of how ugly they are) and slap them on.
if you cant afford OEM, just buy some BMW centrecaps off ebay and slap them on anything you can find.
  • Like 2
Ohhhh reminds me of this guy I know must be 40 (married) often goes to bars trying to pickup with his '7' series keyring on the counter.
It's a 2003 7 series..
Edited by UNR33L
cant afford bigger wheels so you paint your tyres.
lmao
its almost like dream boats with an M sport referring to it as "my M"
mate youve got a f**king 2.5l na econobox with an overpriced spoiler option. sit the f**k down.
  • Like 1
Guest
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
