My car is alright, ran out of tyre grip approaching turn 1, locked up, released, locked up again, released, locked up again... just went straight off the track into the kitty litter at about 120.
Tell you what, that wall comes at you mighty quickly... Ripped off the bottom of the front bar, cooler piping, bent the body metal where the cooler piping hole is, ripped a rubber joiner in half. Don't want to start the car since there's like a kg of sand and gravel in the piping... trailered it home and its now sitting on the street out the front of my house, now I need to work how how to get it 20m up my driveway into the garage. I'm thinking just AFM directly onto the crossover pipe so it'll run.
Went out with some of the guys tonight for dinner and drinks, 54 Jack and Cokes later I'm home.
bahahaha, probably went a little over zealous thinking it was only one parade lap - got a bit out of shape into 3rd gear wheel speed must of shot up to 150km/h + easy and touched the grass nek minit in a spin, too much iracing not enough real racing
serves me right for f**king around a bit - got some stern looks from the officials down pitt straight
Edited by UNR33L
undo all pipes, unplug afm, drive it up on limp mode. done.
good lines till then.
did the exact same thing on my first ever track day.
actually on my first lap of my first ever track day!
hit gravel trap, realized I was going to stop...looking in mirror saw a MX5 coming at me backwards....powered the FK out of that sand trap!!!!!
changed underwear...went back out.
Guest
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
    • Seriously though, it's the Shaft Autoservice high mount rear spoiler: https://az-style.shop/items/5ffaad5a72eb464137a6edb1
