i love the people that go on about Reps being deadly...
If half the national comp level drifters can use them and hit ripple strips sideways at 200kph without issues, somehow I doubt some phaggot in a VW doing 3kph to get up a wooden plank into shallow driveway to go to a circlejerk hardpark meet has anything to worry about
I dunno, examples of drift cars with limited use with shock loading can't really be compared against long term use with multiple heat cycles.
Cheaper wheels & metals would fail due to heat cycling & cracks propagating.
Drifters would probably use multiple sets per season & wouldn't clock up near the amount of km's a daily drive would do...
My drifteks have had a very hard life so far, road and track. No issues as yet...
The missus Audi rims are shite though, leaking from the factory and cracking badly through the lip from careful road driving. I have also cracked oem 350z rims, and seen a few others cracked also.
LOL
Send someone a vector graphic
"Do you have a better option for the diagram. We are putting it in our flyer and the resolution is quite poor."
Send proof of resolution being adequate by zooming in on the vector and screenshotting it.
"That's much better, I'll use that instead" - referring to using my screenshot jpeg
  • Like 1
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
