It was supposed to be Alex's post quoted but this forum app does weird shit like that... Nfi where that post even came from, it's nothing I've read anywhere
yeah, I clicked the link to original thing and it just crashed my phone app... presumably due to the extreme retardation of the thread
Jono what is that ramen noodle contraption and how much do they cost? Might be easier than doing my shit on the stove
Interesting drain hole
lol'd hard at chicken strips, but there's an example of something looking shit and tasting good - I know that shit tasted good
wtf you on about? is there another thread im missing out on?
I know a guy who is in the market for a good 135i, srsly he is out test driving them now.
What's wrong with them?
Nothing it's perfect for a hairdresser or flamboyant tax evader Edited by alr33x
Supposedly they respond well to a little bit more boost, and BMW engines are good.
370rwkw in a 135i, with BMW everything else? 3L modern engine for dat response.
Why would you ever want a R33 in relation to it other than cost?
Srs question. Would strongly consider one if (when) I ever write my car off again.
Speaking from experience? :P messy breakup? that's what I'm worried about, bitches going cray cray and destroying your place if / when you want them to move out
That rule doesn't apply if they're paying you rent right..?
yes and no. certainly not messy which is good.
you can be smart about it but what freaked me out was that if someone is applying for welfare and meets all criteria except is living with a spouse/bf/gf/whatever, that person is then financially responsible for the other (if you earn enough, and by centrelinks standards it wouldnt be much). living together for 6 months that is.
Also, i had planned to go down the path of getting a legal documented created to state X was a tenant and paying rent, on the bond etc. not de facto by default. I never ended up following through with it though.
yeah mates mrs stays here like 4-5 nights a week too.. might have to have dat awkward convo and ask for contribution toward bills if shes gonna spend more than 50% a week here..
f*kn jump started in iracing and screwed my race up, then its annoying that you gotta wait another hour before any more official races lol
Edited by UNR33L
What's the Altona rental market like Alex? less stigma than Laverton...
good but you wont get much in altona for 400k unit at best and even then im not sure these days.
wouldnt worry about the stigma its not your problem lol
This happened in Project cars. Didn't know I had hold the brake pedal for go karts, it started rolling forward and race ended straight away. Stupid game didn't even say I got black flagged.
Guest
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
