It's a 4 person shared house, with 4 people living there, Everyone with friends/partners/cars parked outside.
Bonus points, between the 4 of us, we own 7 cars. Then add the cars of all the other partners and friends, yeah, it's fair to say there's people around...
3 people in a 2 bedroom unit can be annoying, sure, feel clustered, yep. But.. 10 people in a 4 bedroom house is arguably more than that!
However, it works in my case. Depends a lot on everyone involved and everyone else's experiences can't be directly compared...
LOL yeah the sounds really suck I've got a whole list but won't go into it
Also lol @ the hipster bikes and dreads
Edited by UNR33L
Everyone will value their own view the strongest. Just because Leigh holds the power doesn't mean his solution is the best for the situation.
A person who waves his power-card to resolve an issue may be seen as unfair in the eyes of others.
Yes it will get a resolution but what implications will it cause down the road; a ruined friendship, a bad reputation etc
Sometimes having the power makes it even more difficult as your emotions can enable a rash action.
As I said, it's not your problem to solve. It the three of you. Understand the problem & if you all come to a disagreement at least you will all know what the final outcome is without you resorting to threatening it.
Spare me your corporate bullshit, the only opinion that matters is Leigh's as it's HIS f**kING HOUSE. What he wants is all that matters. Anyone who doesn't want to accomodate his wishes is free to live elsewhere.
ie unions.
Good thing we don't care what 'others' think, especially those with no f**king idea what they're talking about
This is pretty out there on the hipster scale....
The beer, the bottle, the label, the glass, the dude drinking it, the fact it's on instagram and.... the name.... the f**king name...
"Mikkeller Orange Yuzu Glad I Said Porter"
Right on!! Just had the same shit with a mate staying at my house...
Tried his hardest to bend my rules, I stood firm...
I dont care for your excuses dude, my house my rules...you dont like it theres the door.. He found it eventually... :rofl:
Is anyone actually questions the his house his rules thing? I don't think so, but people are pointing out he may be being a bit unfair and that may make him leave which may or may not leave him better off
Fark it's cold.
Guest
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
