Defamation = a falsehood
If it's true and you can prove it, it's not defamation.
But that's just the law...rules of SAU are a different ball game and just because it's legal to post a true story doesn't mean the mods will allow you to report your negative experience about a workshop because simply put, they don't know what's true or what's not and libel appearing on SAU can leave the forum's owner liable for prosecution should the stories/experiences turn out not be true...
  • Like 1
Anyone good with basic legal advice, mainly concerning defamation?
I took my car to a local tyre place to have my guards rolled, and it was subsequently damaged after they used a trolley jack to lift it without any sort of adapter or rubber pad.
Now I don't want to put them out of business or slander them, but I do feel its necessary for others to know what happened, especially after I they refused fixing it, or any sort of reimbursement.
Can/should you name businesses online and post what happened, or can it land you in trouble?
They probably arent. But if they are Google review them with an accurate account of what happened that'll alert others.
They're probably some slap shop like most after market car places so you'll likely get threatened with bodily harm or something equally professional in response.
Tis why I stick with manufacturers / big companies.
Yeah I dunno enough about it will have to see my guy
Going back to the loan talk, found my papers 4.28% i think it was.. not sure if it's any good compared to you kents
Edited by UNR33L
Rate doesn't really matter without context. You need the comparison rate. For all we know you could be paying more on your 4.28 than dezz on his 4.7 or whatever.
It's like talking power figures without taking weight into consideration
Meh I'm not in door to door racing.
Also most of the pulsar challenge guys are very quick.
New qualifying record at Winton is 1:42 flat. That's with controlled coilovers, RS3's and stock everything else (80~90kw atw)
Technically when it's a pulsar meet it's backdoor to backdoor racing
Anyone else getting bad gateway when trying to open this thread on a pc? Opens fine on the app but not on pc, yet all other threads open fine...
Not today, last night I had a few... sticky cache with the front end load balancer I believe... If it does it again, try change the page number... see if it loads then.
Guest
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
