Vic WL
My 040 in tank pump has been noisier than normal for the last month or so. Thought it was my imagination being overly sensitive to all the sounds my car makes (Skyline paranoia) and Leesh telling me she can't hear it.
So I took off from the lights today showing an HSV how it's done and hit a brick wall on high boost in second; thought I'd done a cooler hose so putted off boost to my destination and popped the bonnet. All hoses secure no sign of a break in. Fuel pump quite noisy on idle now, and especially noisy when the variable voltage kicks in with throttle on...Leesh can hear so it's not my imagination.
After 5 years of faithful service, is the 040 dying a slow death? Now feels like I'm driving a ticking time bomb. Gonna buy another one but fearing there may be another issue at hand. Is it possible fuel lines / filter / rail have a blockage and the pump is noisier because it's trying to suck a softball through a straw?
Started getting noiser pre-98 octane switch, but now feeling like the switch has aggravated it further...possibly because I ran the tank pretty dry or the 98 has caused some crap to unclog and re clog somewhere?
Sincerely,
Birds
inb4 get a different pump - if I'm buying a new pump another 040 is going in! 5 years is nothing to sneeze at and 2 of those with ethanol when it's not even sposed to be compatible with it.
get walbro.....im on my 3rd in 5 years...at least it quick to change now.
I swore I'd never do another 33 in tank pump again after the first installation...it's a nightmare for anyone without spaghetti arms. But here I am...
first time had to modify the loom for the pump as well for the walbro, and think the s14 tank as bad as the R33 one.
could be worse, to do the one on my ute you have to remove the tray, or the whole diff assembly and then the tank.
Birds
040s get f**king loud when they start dying
Source: killed multiple
Get a 460 pump and for gods sake redo all the wiring in one hit
Yes it is annoying
But better than doing it 9 times and WAY better than having your car die because you have a powerFC that wont save your engine by cutting all your fuel when you hit 18:1 AFR on 20psi.
  • Like 1
Birds
Yes it is annoying
Appreciate the concern but I don't see it popping my engine anytime soon while I'm driving around off boost. Worst case I end up stranded and needing a tow. It already leaned out on me today on boost, that might have been a lucky experience but now that I know it's on the way out I'm driving cautiously. That this one lasted 5 years is a good enough interval for me to suggest I installed the first pump properly with good wiring and in a good position - plenty of people kill walbros/Nismos/bosches in shorter time; replacing fuel pumps is just a fact of life for modified cars and in-tank pumps that cop abuse from tracking etc. Everyone replaces them. The 040 is cheap and to a degree it'll be take out and drop in cause the hose lengths are already cut for it and wires soldered to correct terminal size. Fk doing all that again for another pump type. Tell you what if this next one goes I'll get a 460 :P
Also gonna keep the variable voltage setup - think this may be a reason for longevity of the pump as a lot of the time it was cruising away on low voltage mode. Also keeps it quiet.
I just find it suprising it supports the power you're making, i.e 270ish on E85. Would have thought itd be close to running out.
If it meets your needs its worth doing it again, but the 040 certainly certainly clogs up more than your average bear.
Mine was doing 335kw on E85 with still room for more.
Also lol Birds you cannot complain about a 33 GTST Fuel Pump fitting. The only thing easier is a 32. Try fitting a pump in a 34 GTR!
I'm surprised they're not more popular than they are (and they are popular). See people doing lift pumps and twin 044 setups in street cars lol?
A single 040 can flow 600hp+...shitloads of headroom on this pump and at $160 why bother with anything else!
Interestingly Just Jap say not suitable for E85 but this website does http://www.dp-engineering.nl/bosch-040-motorsport-in-tank-fuel-pump.html
On that note, anyone know what makes an E85 pump an E85 pump? I'm not sure I buy the gimmick when I've been running E85 for longer than the designed for E85 fuel pumps have been around - where is the test of time?
Come around after work and fit my new 040 - will supply tools and pay cash more than RP pay you by the hour!
That^
I don't understand his logic...if he took it apart and found impeller blades corroded away it would make sense...but he's showing the mesh covered in sediment? These pumps sit at the bottom of fuel tanks and suck lol
He'll get a shock when he pulls out the walbro in 12 months and it looks the same...
Guest
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
