I need to find a new barber/haircut place & closest is in Brunswick...
Just a skateboards ride away
I went for a job interview in Fitzroy, was a small office.. got there about 7:45am waiting for the guy to get in because was just him in the office.. rocks up on a skateboard and skinny jeans
Edited by UNR33L
  • Like 3
27yo, no accident, no fines, weekend use. $10k r32 gtst
$1900 a year full comp insur Shannon's
$1300 a year full comp JustCar
WTF
I'd sleep better knowing Shannons wont dog or backout of a claim (as much as) like Just Car would. plus you would get your moneys worth on choice of repairer. (Micolour vs Shiny Captiva Smash Repairs Inc. or Final Inspection vs Southland Carpark Detailers)
the gloria was insured for $14k~ and was $1600 i think.
what if you later married some single mum, and you were talking with your "son" about his childhood, and how he stole this mad as fk skyline matching the description of yours, at the same time yours was stolen.
And he is now in his 20's
and his name was mohsen
Was all about Shannons with their great premium and great coverage and all that.
So much so, housemate called them re: S15
Something like $1500ish (with CAMS license) for 20k covered
Called Famous insurance... got it for like 900 for a year, can park it on the street etc to boot.
Somewhat suprising
  • Like 1
How come they give you insurance for 900 yet Pat got quoted 1900 or what ever it was and parked inside a garage?
Actually thinking about going 3rd party on the MV this year.. maybe ride ~2000km a year these days. ~1k is a fair bit for not using it that often.
Edited by UNR33L
Not sure, I am personally with Shannons, something like $1400 a year (I cant remember now) for 32k covered
This was for housemate, they quoted $1550 (with cams licensed, 1750 without) for 20k covered for S15 at the same address.
but then Famous undercut that quote by $600 a year, and didn't mind about it being on the street.
Will be giving them a call to see what they quote me when renewal time comes up
Somewhat suprising
hmmmmm
just reading their info... they can cover track days for up to $10,000 if your car is damaged (if it hits an object or car). (money is for your car, not other object or car).
might also chase-up RACV classic. and Lumleys. they all told me to go f**k myself when i said i was under 25 a few months ago.
  • Like 1
Guest
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
