Perhaps if they weren't blocked at every turn it would be a different story
in fairness, their utes/trucks store their work-gear & tools for the job. They cant be parking 500m down the road & running back/forth for tools etc
Their car is their tool; the location of your car whilst working at your office wont impact you other than arriving/leaving times.
I'll agree on that to a point. But plenty of people use a car to fulfill their work obligations and they don't get special treatment
Nope.
Plenty of jobs have "carry stuff" requirements
Nope.
The utes/trucks may be used as a mobile workstation for welding/cutting/fabrication along with storage of tools.
Yes, people may use cars to fulfil their work obligations, but if it involves anything more than the above then they should also get a permit.
everoyne would expect to see an LS1 under there.
NOTA33 would be more entertaining. wish Tony could sport NOTGTR.
you should let the engine do all the work and get T51 just for the street cred and to have a chance of being photo'd when near a 34GTR
an electrician with a victorian licence cant do electrical work in WA or QLD without going through their hoops and licensing process.
I highly doubt foreign electricians to be granted work visas and to just magically get jobs (legally) when:
a) there is a work shortage with many in the electrical industry looking for work
b) immigration has tightened up like a ducks butt since 2011-2012
c) the companies with the power/cash to do 451 visas would most likely not risk hiring people with questionable skills and knowledge. (especially blue collar workers)
regarding unsafe cabling and installs in houses... home owners agree to it because they dont want to pay the extra for a proper job. someone beats a quote by a few thousand dollars and most people dont think twice about it.
Who do you think you are telling these experts what's what?
Q&A doing its usual close ups of audience hipsters with ironic beards and intense looks of concern on their faces
How much more is my mocha chai latte going to cost if this new tax comes in?
God these rainbow display pictures are annoying, yes I support gay marriage - no I'm not a sheep..
http://www.theatlantic.com/technology/archive/2015/06/were-all-those-rainbow-profile-photos-another-facebook-experiment/397088/
could be a potential facebook book experiment, monitoring how peoples views change based on their friends & how long the change lasts.
Guest
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
