How much was the tomei one?
Got it from Miguelone during his "I no longer have a skyline" clearance sale... Can't remember, but it was definately more than just the sentimental value...
iirc it was around break even price.
Unlikely to find another. Not that I've been looking recently but when I was collecting all the green anodized Tomei bits it's the only one that I didn't see come up at all.
How was it?
well it ended up at 17 courses..so that was a bit over kill.
every item was amazing on its own, but so many strong flavors started blending in with each others.
less courses with a cleanser would have been a bit easier.
the whisk gums at the end were out of this world however, only had tried 2 in real life and tasted exactly correct.
11262211_10207066817211758_7451064058628
they call it a once in a lifetime event, and I can see why, more than that and you would die of a weird combo of heart attack and gout..
Guest
