BMW was a loaner from BMW on a ambassador program.
tomic was on P's and got an exception to drive it as it was "work"
got busted doing burnouts BMW took it off him and cops gave him ticket for being a hoon.
few months later he got off p's and bought said Ferrari.
shortly there after went to court re the hoon activity.
lost license.
lols were had.
beers were drunk.
It's also a two way street...you can't expect people to respect you regardless of your position of power if you act like a jack ass. People who say "my game my rules" end up playing alone.
Which is why bosses who don't respect their employees end up with poor employee satisfaction and a high staff turn over. Do it enough and their bosses start asking questions too.
Lot of this Tomic hate stems from jealousy cause young kid with lots of money having a bitch about something...meh...I say good on him, at least he's standing up for himself instead of just prostituting his dignity away for the sake of earning $$$.
Or possibly it stems from when he was given an exemption to drive the M3 on his p's, solely as he was a celebrity and it was "the only form of transport available for him to get to tennis" and he then used it to cruise the strip every day and act like a flog attracting as much attention as possible. Then when the police showed up to pull him up for the 3rd time he refused to stop and instead drove off home and called the lawyers... but not before hiding behind his gate calling the police names, then getting on tv and accusing the police of racially profiling him...
It could also have been that...
Soooo jealous
Looked under my car when it was on a hoist
bad idea
such a bad idea
also, are AD08's still hugely pricey? like $350+ per tyre pricey?
Why not buy Ventus V3? Seem to be $250 a tyre and from all accounts grip better
After my NT05's lasted 7000kms I am now sad.
bad idea
such a bad idea
I think you just had a conversation with yourself
Entirely possible, but was under the impression ventus were waaay more pricey, like, on-par with the AD048R
Given the echo chamber that is VWL, sometimes self-conversations have the same content
bad idea
such a bad idea
why? getting expensive ideas or things not right?
if the same workshops/people work on your car regularly, soon theyll start taking the blame for everything that goes wrong ;)
Nah. Was at scottys. Found out I had 3 bald tyres (1 is brand new and just replaced, woot...), snapped/bent steering/suspension components.....again.. and my exhaust idea had to be massively revisited for another time.
I have a couple of spare new AD08Rs from the import monster AD08R bonanza but love them too much to let them go for as cheap as they did
Solid tyre even at 2012 issue or whatever they were
From what the internets says, the Hankooks go for $250ish and outperform them, the AD08R's go for something like 350 unless you find a deal.
Almost bought the guy who was selling 2x for 500 awhile back (ad08r's)
Just knew my rears were worn, but on the indicators after 7500kms on NT05's was.. yeah. I suspect the Hankooks last about half as long as the AD08R's. Hence the query about them before HWP says HEY MATE BALD TYRES OFF TO DEFECT LAND and which they would be correct to do so.
That's The only prob with NT05's
The indicators coke up reeeeally fast. The trick is to not give a f**k and drive the shit out of them anyway. I used to rock mine well past the indicators
Guest
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
