How do you drive around with broken suspension and not notice till you look under the car?
More to the point how do you have plural damaged suspension?
car has accident history? (or is this a new shell?)
"Greg"
This is a new shell.
Yes I meant the hankook RS3 sorry. If they are equiv, and $250 a tyre, well.. that's some coin saved.
re: My suspension
I hit a kerb, hard. Damaging a wheel, and bending a tie rod end.
Got that fixed and wheel repaired and new castor arms. all good.
Went under car, noticed the bracket I don't know the name of (what the front sway bar bolts to) has literally snapped off in half.
So that's nice. No idea when that happened.
I also asked TT to set my ride height at 350FR and 345R height. It felt floaty as FAAARK in the rear and I just blamed it on hicas till I actually measured the car and found the front is 330mm and the rear is 368mm.
So yeah....
How f**king hard did you hit it!? I went through a HUGE pothole a couple of weeks back. Took chunks out of both LH wheels and threw my alignment out. Gonna call the council and see what they'll do about it.
Working side (for reference):
Damaged side (for lulz):
Note: I did not notice this occur. It happened some time after traction tyres installed the castor arms and replaced inner tie rods.
Nah, ever since I got the rears put in, I noticed it felt really tail... 'rolly' as though the weight balance was 99% front, all the time. But I supplied the struts and springs to TT, as they came off the old car.
But stupid me didn't really think about the fact that while the fronts came off my old car, the rears struts were swapped, so the setting for rear height was lost when that happened. Did give them ride heights but as they (TT) figured they were swapping from one car to another they didn't need adjusting.
I had no idea the front sway was basically removed from the car via kinetic force.
If it all gets fixed up and it still feels weird then I dunno. Car didn't have that behaviour on the springs it initially came with, nor did my old car with the exact same setup.
but I'll probably blow my engine up again between now and when its time for another alignment
so this was the tyre that won street class at WTAC first 2 years.
then Yokohama sponsored and forced people on to their tyre.
so yeah it good.
That's The only prob with NT05's
The indicators coke up reeeeally fast. The trick is to not give a f**k and drive the shit out of them anyway. I used to rock mine well past the indicators
This is what I did.. although in wet you had to be real dam careful
I think I got 10,000km or maybe bit more out of them.. rears were shagged but fronts were still fine, usually I go down to the wire.. alignment Greg?
Edited by UNR33L
AD08 >>>>>>>>>>>>>>>> RS3
By far.
Why? (srs question)
Longevity?
The NT05's are just touching the indicators in the center now, on the sides there's maaarginally more, but barely enough to catch a fingernail on.
Where else to go for alignment duties? TT always been nice to me, but heard a few things now...
i havent really tried many reputable workshops in the south/east, but i still happily do the drive to Thomastown for Centreline.
Yeah i got an easy 10k from the fronts for daily duties and a few deca's. Probably would have got to 15 but I usually put them in the rears and fried them.
I disagree about the wet though. A car that needs NT05's is going to f**k you in the ass in the wet no matter what
That's a good point, when road is just wet its true it's more so when it' soaked with a few mm of sitting water even shitty tyres with channels to get rid of the water makes me feel a little better instead of a flat bald tyre aquaplaning
Guest
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
    • Set of R33 GTST Calipers, Rotors and Pads. Calipers just taken off my car, rebuilt about ~30,000km ago. Rotors have done about ~20,000km total since new. Pads have plenty of meat. One set is DBA XP (road, hills) and the other set is Forza FR6 (track) Still working perfectly, not rusted, or seized or whatever the hell that greets used brakes. All clips, bolts, retainers, slide pins etc included. Also have OEM handbrake shoes I can throw in there if you're doing a conversion. $650 for the lot, SE Suburbs Melboune/VIC
    • I feel I have covid right now. I spent the time between Dec 21 and Jan 31 pretty much working 16 hour days on the car after it got back from paint. It turns out you generate a long list of "things to do" while the car is off the road but functional. After going to visit my mate for a "Couple of hour job" doing the brakes, 3 full days later I got home There was more on the list, (it got added to while sleeping on couches) but as everything on the list got enthusiastically crossed out as it happened, I've actually forgotten what they were. From memory there were bushes that had to be pressed in and out, washer jets to fit, etc. Some Gregging highlights: 1) The panel shop covered up my washer jets and painted over it. Good job, I think. We had to drill the new bonnet to fit new ones, which was understandably extremely scary. 2) My handbrake on the RHS is f**ked. After never adjusting it forever and learning on the fly, this one is still on my to-do list. It tightens when you pull the lever, but at about 10% of the tension that the passenger side does. Thoughts on what causes this would be great. 3) Pouring an entire liter of brake fluid over the reservoir because I forgot how to use my pressure bleeder. DON'T PUT FLUID IN THE RESERVOIR. IT WORKS BY USING PRESSURIZED AIR NOT PRESSURIZED FLUID.   471907729_9242915229093447_2708910336906717367_n.mp4  I can confirm the vents work great though. 4) Some of the bodykit fixings were f**king awful. I'm talking screwed in with what was at most a 2mm screw, and could flap the kit around by hand. Too many others to mention. They came in, went out of my brain forced by other stupid tiny things that came up and "While the car is on the damn hoist we can fix them" which was a mission in and of itself, because the car has skirts and is thus a pain to put on hoists. Because we had to buff the windscreen to get rid of the overspray, I also had to very gently wash the car. The "Run 3 wires" task was to re-attempt another gregging thing which was: The LS1 ECU in Australia does not have oil pressure wiring because the Commodores do not have a 'real' oil pressure switch The Corvettes in the USA do have oil pressure wiring because Corvettes have a real oil pressure switch. The ECU is the same physical ECU. So what I could do is pull the ECU apart, run 3 more pins and run it to the OEM oil pressure ECU, and the ECU should do this. What actually happened is that Greg did this with some not-so-proper-wiring/connectors to the ECU pins which 'might?' be okay put the car back together, and then the fuel pump wouldn't prime. So you can imagine I immediately undid all this work, put the ECU back into it's original configuration, thought I'd do some more research about what connectors the LS1 Ecu actually uses... and try again later. Except still no fuel pump prime. After a lot of sadness and checking/double checking it turns out it was the relay in the boot that controls the fuel pump. All I did was switch the trigger wires and it worked fine. I looked at the relay and it was covered in bog dust and was unknown years old. It's since been replaced and working fine. After I got the actual connectors, and the wires were ran I gathered my strength and repinned the ECU and Voila! I apologize for these MMS  472164532_8829400773820369_5410969472548349643_n.mp4  And even via ODB2 on the headunit, woo. Now Torque Pro can raise hell on track if it gets too low. It has a wonderful EMERGENCY_DISTRESS_SINGAL style warning if it goes below a certain threshhold. 472585876_9345134268844369_146554337148747327_n.mp4 TLDR: Car great. HFM kit works. So much cleaning. Buy my old stuff. Thanks.
    • That's a hell of a question right there and so broad that you could get 100 different answers and have them all be correct.  To avoid me typing up a 2000 word thesis that doesn't answer your question, do you have specific things you are unsure of? Does the car currently handle in a way that you don't like? Or is it closer to, you think the car drives fine currently. But you'd like it to be better, but you don't know what that 'better' is or what that 'better' feels like?
