but but... I got 7500kms on my NT05's driving like a pansy...
I got like 10-15,000km out of my rear NT05s after drag day (burnouts) street powerskids etc.. your alignment must be screwed :P cos my fronts were still decent like 85-90% easy confident the fronts would of done 30,000
Edited by UNR33L
I specifically bought them thinking I'd get that much wear out of them.
Got dat alignment multiple times in that time frame for any change to make sure they last the distance
they just..... didn't
Send Barry $6k worth of engine during the week, courier confirms delivery
Call him up on Saturday to see if he received all okay and talk about options
"Don't know what you're talking about mate"
Silence
"Nah I'm just joking it's here all good"
Barry pls
  • Like 1
Guest
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
