Ah well that's good, what was wrong with it anyway?
Engine I sent him wasn't from the GTR - that's still in there and I may actually sell him that one when we take it out cause he loves collecting RB26s and 2Js
Surely I can't be expected to hold my own scotch while cornering at phillip island... the long straight is enough to have a sip and savour it, just in time for the require liquid courage to kick in for turn 1.
Guest
