Walk out to car to find right rear AD08R nearly flat
Either fast leak or dodgy neighborhood fkin with my property again
Lose lose for Birds
one of my AD08R's deflated unnaturally quickly. other 3 were fine. was in a backyard, so no one had touched the car.
That's some Greg shit right there
Did it do it again or a one off?
Fitting AD08's to my car right now
Got told the fronts (Michelin Pilot sport 3's) are a horrible match and almost certainly will result in me binning the car
Greg issues occurring before even using them now
Widths of Front vs Rear?
I wouldn't say the tyre itself is a horrible match... your fronts aren't hardly 215 Chinese tyres... Unless the tyre place thinks you're going to be tracking it... in which case I'd be recommending AD08R's on the front as well or the rears will just push you off the track in a greg level understeer.
Coming from 245/275 Nitto NT05's
235/265 now
Pilot Sport 3 fronts, AD08 rears.
Did say I may track it, but he was more concerned i'd bin it driving in normal traffic or highway cruising.
All tyres involved were a great deal, etc.
Figured it'd be fine, if anything the PS3's should be more grippy than the AD08's, hence them being on the front of the car.
But yeah. Slip angles apparently very different, told to take EXTREME caution, and I'd notice it within 5kms of driving the car if its gonna be a problem.
I have AD08R 265 on the rear and AD08 255 on the front
It doesn't understeer really, in spite of the fronts being a street version of the rear semis
Actually is quite balanced feeling
I also postulate that the rears will wear down faster and return to a slight oversteer
It doesn't understeer really, in spite of the fronts being a street version of the rear street tyres
fixed that up for you...
  • Like 1
Guest
