Today was rather interesting.
Went to get some food, look to my left and there's a fully grown man with a beard in a pink dress.
Righto then.....
no that was a mirror
fail aaron
Aloe Blacc is shithouse... I can't stand that f**king song
+1
Aloe what?
apparently its good for sunburns n shit
Did you know Northern Italians despise southern Italians with a passion and at one point wanted to break away, or cut Italia in half to form their own state? They view the Sicilians or Calabrese or any other Southern as bogan like since the southerners tend to be involved with mafia allot or other underground organised criminal organisations.
Southern Italians at one time in history were ruled by Moors, hence the reason Southerners tend to have more darker features and olive skins.
http://www.youtube.com/watch?v=kXjcf47y-zk
Northern Italy is very industrial and fairly wealthy. Southern Italy remains poor and undeveloped. There is much resentment in Northern Italy that their tax dollars keep getting poured into the southern part of the country, year after year, without the south developing its economy or anything changing much.
There is actually a small separatist movement in Northern Italy that has occasionally become violent. I think they were more active in the 1990s and have calmed down somewhat.
Italy has an term called mezzagiorno, it is the line that divides the north and the south. The 2 regions were culturaly, geographically, and historicaly separated in time. Southern Italy was poor and neglected, northern italy was the hub of the renaissance, art and culture and later industry. Southern italy shared a similar heritage with the southern Mediterranean culture where northern italy shared a heritage more similar to the northern europeans.
Edited by Flynnn
If you're doing career you'll have to drive a few seasons and get offers from the bigger teams if you're good.
Should be able to choose any team u want in the other modes though
Been playing GTA 4 lately, right now in fact
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
