I've been to Naples in the south, and it's one of the dodgiest places ever. Get off at the train station in Naples and you really have to watch your shit, lest it be snatched from you. I was ok, but unfortunately, the asian tourists are often seen as 'easy targets' and are set upon by the local scumbags. Once you keep going south however, into Sorrento, Positano and Amalfi, it's probably more beautiful than the places in the north of italy imo, so I don't understand why the northerners think they're so much better.
His quoting google wouldn't read into it too much, how was ya trip overall apart from been cut short?
Yeah it was awesome, really enjoyed it. Glad to be home though, Australia is without a doubt the best country on earth!
I have one of those getting resprayed at the moment...will be selling once it's done :)
Gotta really put your foot on the brakes to make them stop hahaha, even just keeping it still in D when you have the choke on :/
Belongs to the workshop, I'll post photos for you when she comes back from the touch ups. Fun thing to cruise around in but we only bought it to do up and sell. Pretty immac condition!
No idea yet but probably more than the one you posted, which looks like a pretty good deal if it runs as well as it looks. Let you know once we get it back and total
the bills etc.
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
