it's quite easy assuming your house roof is tiled and you're able to get up there
just open a few tiles squeeze yourself inside your roof find the manhole and go down through it
used to do this quite a bit, wasn't always my house :ph34r:
Yeah it's do-able, but not an easy task getting on my roof with out a ladder etc... and woudln't fancy my chances of finding the manhole without first creating a new one when I fell through the plaster trying to navigate my way through the pitch black roof space lol
feel your way through it. wax on wax off spec
i have the key to the front security door but not to the main wooden door and sometimes my mum locks it so i cant get in...
usually get in through the kitchen window. the lulz when my mum got up and thought i was a burglar one night..
I rekin she locked the door out of habit, I never do and it had to be unlocked for us to walk out of it in the first place so yeah....blame her.
I can attest to that - It's the same habit I have, hence I locked myself out :(
Without even thinking I locked the door when I was only going out for a min lol. Was on the phone at the time.
Least you got in man, breaking windows to do it in a PIA
my tan + the dark night and my blistering pace, you'd forgive them for thinking I was a nigra
Laughed out loud at this, in the tearoom at work. I still reckon you should have macguyver'd your way in though
its like people saying my cars jdm.....
which is mostly the honda dream boats saying ti about their aussie delivered eggs.
anyways, diff place just called back and told me my diff is cactus.
can someone please explain ratios to me?
In mathematics, a ratio is a relationship between two numbers of the same kind[1] (e.g., objects, persons, students, spoonfuls, units of whatever identical dimension), usually expressed as "a to b" or a:b, sometimes expressed arithmetically as a dimensionless quotient of the two[2] which explicitly indicates how many times the first number contains the second (not necessarily an integer).[3] In layman's terms a ratio represents, simply, for every amount of one thing, how much there is of another thing. For example, suppose I have 10 pairs of socks for every pair of shoes then the ratio of shoes:socks would be 1:10 and the ratio of socks:shoes would be 10:1
Yeah I know you know what it means, but even JDM doesn't mean anything, people use it as if it means Japanese development motorsport to make themselves feel special about owning an import, but it's like calling a silvertop taxi ADM....
Guest
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
