  On 17/01/2012 at 11:46 PM, Mohsen said:
its what i have been doing all week. i feel like im donna die lol
From going out? work? Or unable to sleep?
  On 18/01/2012 at 12:10 AM, Rekin said:
The youngins always have energy for that haha. We getting old Tony :(
Yeah I need atleast 6-7 hours sleep otherwise will just feel like a zombie in the morning
  On 17/01/2012 at 11:57 PM, Birds said:
Why don't you post some song lyrics about it?
ill call you later and sing to you
wake up at 6:30 to go to work, finish around 5, go home and have a 30 min power nap and then end up catching up with friends which ends up dragging on to the early hours of the morning >_<
Farkin this...there's that magic (or not so) age in your twenties where you just can't do it anymore lol. When I was at uni I could go out on a thursday night and be at uni the next day on 4 hours sleep. Anything less than 8 these days and I feel like ass!
lol @ thread Alex.
Loved this:
  Quote
Where people will sit on or just under the speed limit. Because we are all eyeballing eachothers cars for what they are, an loving every bit of it
Probably because their cars are all so "stanced" they cannot drive anywhere above the speed limit for fear of flogging out tyres, bump stops/suspension and breaking god knows what :rolleyes:
Oh how I am LOL'ing at the moment.
  Quote
If people copied what I do, which is spend hours and thousands of dollars on what I love then there is no issue.. When people buy coilovers and throw on XXR's that dont even break the $1kmark, then there is an issue.
lolfag
Guest
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
