Seriously though if the tyres can't be changed without scratching rims... Or a properly prepped/painted setup that will last against track work... Surely possible?
Can be done with car rims. Can't see it being much different
powder coating is hard to scratch in my experience
Two things that usually kill people on bikes, being their own stupidity/inexperience or other drivers on the road. The latter can't always be avoided but there are certain ways to ride in traffic that improve your chances of surviving :thumbsup:
I think that can be said for cars as well.
It can be, but chalk and cheese as far as the accident outcome goes.
So true, my old man has ridden bikes since the dawn on time.
On another topic.
SAU VIC are having a scavenger hunt, members only on Sunday. But anyone can turn up to the BBQ at the end point.
So if any of yous wastelanders are bored on Sunday around lunch, head down.
Ruffey Lake Park
Watch out for the SAU VIC flags.
Plus it's going to be great weather! 31 Deg or something
Korean bike, not the best quality but have come a long way and look awesome, especially for the dollars. Would be perfectly suitable for a bike on your restrictions, probably what I would get if I did it again. Don't sound half bad either.
I thought megelli were British, though made of Taiwanese parts
huh, my bad you are correct. I generally slump anything Asian that's not Japanese into Korea. I was aware the company was different though but generally go by where they're made.
British bike
'Designed in Europe'
Made in Taiwan
:turned:
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
