Mixed too.
Lambs on Commercial Rd, next to the gay bars :)
double lamb all the way, never seen one under $10 - with decent meat.
Stalactites for instance, half the Souv goes in the bin as it's just chunks of fat. Fken terrible >_<
Stalactites are awful, I don't know why people rave about them. Meat cuts are bad and huge chunks too. I love my lambs because they are small pieces so easy to eat and always good quality meat...has to be Commercial Rd Lambs though. The rest of the Lambs along Chapel St, not a fan...similar to Stalactites. Give gay Lambs a go and see what you think...they do double meat but I don't know the cost. It's about half way between Punt and Chapel.
I'd be curious of the predominant thought process when girls wear leggings/jeggings out.
1. Because its comfortable
2. So all the guys can stare at my ass
3. Because they fit easily in motorcycle boots
And they are comfortable :closedeyes:
Edited by JEPPE
ROFL @ Gay Lambs love it :D
I don't mind big chunks of meat (hohohooomo), it's just piles of fat I cannot stand. I mean of course lamb is a fatty meat and hence where the flavour comes, but Stalactites is 100% woeful. Only thing is it's walking distance from work @ 4am and is open on a Tues night etc.
I'll drive to work on the w/e though so will give that one a crack on break.
Guest
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
