Care to point out where I may have been trollin chief?
Interested to see if you can back up your accusations
It's how we roll.
People bullshit and lie aaalllll day long. Always know the ones that are gonna say one thing, and do another.
Prime case atm :)
just been for a drive in grants gtr, was very nice!
very nice guy too! :D
Was lovely to meet you, my mum liked your car. Then she asked why buy my car, had to explain what happened to me 2 years ago (had 33 gtst before the first gtr).
ahah :P i can understand that!
she can buy it if she wants! its for sale!
Was next to one at the lights on Sydney Rd. and I'm pretty sure it sounded just like my 33 with the exhaust on whilst it was idling.. taking off however had a lighter tone to it. Changed three gears by the time mine shifted to second despite the driver just cruising it
Yeh i've cruised next to a 35 once... when just cruising the gearbox sounds so cool :D a bit like my ZF when cruising but better. Changes at like 1500rpm lol
Zing
All you do is post shit about doing such and such because it imprsses women, yet you seem to spend an awful lot of time finding and looking at photos of women that wouldn't let you clean their toilet. Where's this harem of women you're attracting with your style?
And don't try to distance yourself from your online persona, you come across as a cocksucker because you are a cocksucker. Funny how everyone else on here gets along with everyone else just fine, but there's an overwhelming amount of dislike for you
Ad hominem attacks
Just booked in a test ride on this for Friday:
A little bit excited, they have a demo for sale in my size and colour :thumbsup: I hope it rides like I want it to!
Wow that is sexy what is it?
SAU VIC RIDE NIGHT KGO!
Mrs is getting her license with s friend as well..
Yay this really could turn into an SAU ride
I agree, don't like the naked's. A Ducati with fairings any day.
I agree with you both, which is why I've been eyeing the full faired... but I really do need to keep it of the track and I know that won't happen with a full faired :3
Guest
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
