I fail to see the conflict mohs a lot of things ... But surely not a sick kunt?
Well he was using "sick kunt" in a derogatory manner so...
For anyone that has missed it, this video seems to be doing the rounds
*tried to embed but failed
Wow 50 police to go and defect cars, obvious where the priorities are...revenue vs. prevent immediate and direct crime that actually has an impact on peoples lives. Love how every car they pulled over was either a P plater or modified looking vehicle. Nevermind the myriad of cars on the road that have shitty tyres or rust buckets waiting to crumple. Top comments were hilarious!
Love how the cop says if you modify within the confines of the laws then you won't have a problem...except for being pulled over for a 20 minute inspection, or having to pay to get your car tested (not to mention the time involved) on a cop's assumption it may be illegal. If they did this to all cars and drivers I wouldn't give a shit.
Got new sway bar links cos one of them was clean snapped, spent 1hr trying to fit just one side to the hardest setting on my sway bar with no luck... Surely there is an easier way? Anyone know any tricks? Used the trolley jack pole to move the sway bar and still nothing....
Sway bar links are whiteline, incase anyone was wondering
Did you jack the car from the k-frame? Both wheels need to be off the ground.
Bashing related death vs motor vechile reated death. Would like to know that stats.
As i see it there would have been multiple people in hospital because they chose to 'go out to the city' vs the road fatalities for that night. Common sense doesnt preval obvoiusly as making sure the car is quiet carries much the same weight as making sure people are safe on a night out...
Guest
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
