sorry mohsen i need ecr33 seats to swap with, cant do er34
kryuzzzuiozui let me know if you are interested
but need ecr33 to swap them for plus cash
lol i can line up some s2 seats you know :P
I agree with his attitude re been pulled over is immature but if ppl call him spoilt for having that car or whatever that's not right since he works for it
Kinda hard to hide an orange m3, maybe he should have thought of that
But the argument of 'if you don't want attention don't drive a car like that' is the same attitude that other people say 'if you don't want attention don't drive a skyline' :P
In other news my radiator blew up yesterday. I find it interesting that the stock R34 GTT radiator is only 15mm thick about 1/2 the core thickness of an R33 GTST-T radiator.
So, that was the problem?
Are you saying 34 GTT have smaller radiator than R33 GTST?
I have a feeling it might be a factor in my high oil temps. Will see, new 50mm radiator should be installed tonight.
Factory R34GTT radiator is 15mm thick which is apparently half that of an R33 GST-T.... Why new car but smaller radiator Nissan?
Its not always about the money, just coz you can afford to pay the fines doesn't mean you should. Its more about not letting kunts walk over you be it a police officer or not.
If he sais he was being targeted i'd have no trouble believing that. But that's just me...
As for the car hmm that m3 is easily f430 money which is what i'd rather have
You raise a valid point Sir.
But it is my understanding you no longer have an R33 :nyaanyaa:
What has he done to the car to make it F430 money? New M3 is about $140-150K?
F430 were about $400-450k new. If we are talking about 2nd hand I would Imagine it would still be about $250-300K
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
