Why can't girls just get along?
6 years at working at the same place and there has always been a tensions/girls not get along/bitching between different sets of girls.
This also applies to girls that I'm friends with too.
All the work guys always get along and also the group of guys outside of work have never had a qualm.
Feel like I'm Dr Phil when girls are breaking down in my office.
Just sit their and listen but you can't touch! A manager has been sued before for trying to comfort a crying employee :/
thats seriously dumb!
human nature is to comfort someone when they are crying..
getting sued for it is pathetic!
Show him your roof :P
carbon fibre shtickerrrr!
Mirror finish :P
:thumbsup:
Hmmm well I have the a1rm sitting there atm so I might get them put in for the time being. Look into red stuff when I get a chance.
not a valid reason to chew through the DBA's.
QFM HPX's are like $80 a pair
Yup a manager got taken to court for comforting a staff member after she was crying. I.e. rubs on the back and a hug.
Case was dismissed in court, but having that mark against your name and months of stress wasn't good for the manager.
So I just sit back and hand them tissues :D
And yes bitches b crazy
And that there is one of the reasons people aren't as nice to each other anymore...you can get sued for being nice and errr...crims with bad intentions get off pretty easily :/
I remember some guy saying how he can't even look at or say hi to people's kids at the supermarket anymore, for fear of being thought of as a creep/pedophile...can relate to this. The times, they are a changin'.
That said, can't wait to get stuck into the ladies at my new job lol
Sexual harassment at a...legal firm? You got balls :P
i have my gtst going in for a rwc tomorrow morning - he keeps telling me my return flow fmic will need to come off..
just wondering if anyone knows where can i find documentation which shows its legal?
I've only been able to find it on the EPA information bulletin
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
