:thanks:
nope hence why it should be interesting lol
was supposed to do that but told em i'm only free 1 day a week etc and they let me do the one day deal
hrmm I woulda done the 2 day (but fair enough if you only get 1 day off work) if you haven't ridden a bike before. They seriously just sit you on the bike and say off you go follow the pack and everyone just took off. If it were my first time on a bike I woulda been like errr.. altho these bikes are pussy and have no power so yeh you'll be fine lol just remember 1 down 5 up :)
Might be worth a look, kunce are asking for minimum $1500 for 10+ year old excels
excels look horrible :/
lol yeah there are some tutorial videos on youtube shows you exactly what to do, looks pretty straight forward but yeah never know till you try
I learnt clutch bike when I was like 8 so cant be that hard :D same as car really find the sweet point and if you let it out slow enough you wont really need to give it any throttle, you wont get out of 2nd or 3rd anyway I have faith! gl with it all!
First day of two is just teaching you theory and how to ride a bike, along with bits about what they'll be testing on the second day. If you've ridden a bike before or confident you'll know how to, you'll get by with just the one day. Maybe tell them your situation on the day and they might give you a little extra guidance before they start everyone on the practice riding again - of which they do plenty. It takes like 10 minutes of riding to get a good hang of it. Just remember to slip the clutch plenty so you don't stall, you can get away with this on bikes as most have wet clutches. They have the idles turned up on the learner bikes, so as Leigh said you may not even need throttle to get moving.
Yeh I'm not renewing never seem to get to sau events/meets so not much point.. Plus sold the skyline anyway lol
it isnt sold untill your side bar info is changed......
you still own a skyline alex.
you do.
I might actually renew my membership and attend some meets once I get a bike
Hahaha I was thinking about rocking up to some on the bike. Can have a small group of bikes following (or leading) the pack. At least the fuel isn't really an issue.
Well except for me...9L/100km :(
That's very fast and the furious lol
"what do you think lance?"
"it's an amazing machine"
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
