nope hence why it should be interesting lol
was supposed to do that but told em i'm only free 1 day a week etc and they let me do the one day deal
There are after hour multi day courses available that can be spread apart for convenience.
Up to you if you think an extra couple of days will be useful.
Full time work - Day 1. On time, stayed awake all day. Great success
I'll give you 3 months before you become a zombie and a slave to the system...working jobs that you hate...for that shit you don't need...it's too bad...the world is based on greed...
Welcome to the rest of your life
Its good earning the money, but sad when you realize.. fark.. this is it. this is life. lol
would be better working 4 days 3 day weekend.. should be the standard imo. ;D
You'd only use it on a hot day or a cold day when not raining.
I want one, where can you get it from?
The only problem I can see with that is there is no Parker. :S
http://www.rhdjapan.com/silk-road-section-headlight-intake-kit-r32-15821
It has parker, i think its the ring around the main driving light.
fml, high pressure sprayed my car and paint flaked off the windscreen wipers which i painted not long ago ~_~
Might have to get them powdercoated or something...
Or learn to paint?
Just sprayed it with black spraycan paint, but its coming off. What i do wrong? :/
Lightly sand back, spray with primer, wet sand the primer, prepsol the surface and then spray with paint. Success! Also...you can use a trigger hose these days :)
This...used to work 4 days a week and it was the best balance between work and leisure. Was so much happier overall with the extra day, and got so much extra stuff done too :(
The money difference isn't that bad either...just that most jobs/careers don't work with only 4 days a week :(
Lightly sand back, spray with primer, wet sand primer, spray with paint. Success! Also...you can use a trigger hose these days :)
i did sand back to metal, primer and spray paint...guess i missed out on the wet sand primer..le' fu~
Also do very light coats of paint and wait for each little spray to dry...even if it takes you 15 minutes to paint them...that way you create layers to reinforce each other rather than just one layer of paint that will flake off all at once. Also prevents runs.
Spray at room temperatures and not in direct sunlight or too far away, otherwise the paint dries before it hits the part you're spraying.
Painting takes a long time to master. I even know how to do it and I still can't do it properly lol.
bah, i'll give it another shot when it all flakes off. Dont have the patience for it haha
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
