http://www.rhdjapan....e-kit-r32-15821
It has parker, i think its the ring around the main driving light.
Works out to be $310 AUS.
Then I assume +shipping... Hmm...
The CF intake / headlight replacement looks great!
Yeah had I left it in there I would have got my money back, probably even made some, but no one knew when we were gonna pull out of it so I cracked the shits / sold up and bought a Skyline haha.
Ah well it's only money can always make more!
fml, high pressure sprayed my car and paint flaked off the windscreen wipers which i painted not long ago ~_~
Might have to get them powdercoated or something...
Or learn to paint?
Just sprayed it with black spraycan paint, but its coming off. What i do wrong? :/
Use Etch Primer, not normal primer. I sprayed mine 3 years ago, used etch primer and black over the top. The only problem I can see with mine are some chips here and there probably from bugs or stones.
Funny thing rates, it's actually good they aren't dropping in terms of the economy yet the sharemarket dips on the news and people get disappointed they wont save $50~ a month... Forgetting the upshot they still have a job! And a relavtively healthy economy
What car you going to build up?
E39 528I
scored it off my uncle. schwartz black, with peanut butter interior. found a late model wreck with the black leather m sport interior.. so i guess ill pick that up instead of the R32 that pat posted >_<
Fk airbags I can see your whine thread when u get done an have to rip em out for roady
valid point good sir.
but damn bags would be nice and comfy as hell
Moh, by the time you're done spending money on it, you're gonna wish you offered that guy $20k for his 540...which you'd be infinitely better off with anyway. And you could actually own a cool car for once.
Unrelated, just took this for a road test...if the gearbox and clutch weren't completely f***ed it would have been a lovely drive. There's something about sitting in lounge chair seats, holding a shoelace thin steering wheel at 40...mph...in 4th gear with a V8 rumbling away. Must build one, one day.
E39 528I
I see, you gonna do a build thread in S/W?
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
