So when most 250cc bikes come with a 130 at their widest? Significant difference between that and a 190...
For a tyre to maintain traction it needs to run at a certain temperature, too cold = lack of traction, too hot = increased rate of break down with no increase of traction.
The rear tyre disperses heat under the power of the drive train so that it's temperature can remain in this 'sweet spot'. Larger bikes produce more heat and friction therefore needing a bigger tyre. Smaller bikes don't so they don't need a big tyre. This is why front tyres don't differ as much in size, because they are not under pressure from the drive train. You'll find the actual contact patch on the road is quite similar between different tyre sizes, providing the bike's set up correctly.
Putting a larger tyre on a small bike would just reduce the overall temperature of the rubber = less traction, stability of the bike, make it heavier and less aerodynamic. So if you're running out of grip it's probably going to be one of the other things I mentioned, not the size of the tyre :)
I'm talking about the wet...the thinner tyre is going to be better in adverse conditions for a new learner like Rimon. See motorcycle section in this wiki:
http://en.m.wikipedia.org/wiki/Aquaplaning
These advantages diminish on lighter motorcycles with naturally wide tires, like those in the supersport class.
Supersport is 600cc. Light bike, wide tyre. So this 'dimishing' is only specific to this kind, and probably not by much. You said 'the wider the tyre the worse it makes you in the wet' but it's more about matching the weight to the width of the tyre, like the Wikipedia article states.
Most likely the bike won't be the thing to make the major difference in this situation. Learn to control a rear wheel slide and that may save you.
Edited by JEPPE
This guy explains it better than me:
http://indianmotosblog.com/aquaplaning
Case in point, Rimon thought that bigger tyres on a bigger bike would be safer to ride with, not always the case.
Congrats Rimon. One day or two? www.bikesales.com.au :thumbsup:
lol... I read the first line. 'Monsoon time in India'. I don't think we'll be getting those conditions here.
Motorcycle Weight: Lighter motorcycles are likely to hydroplane more than heavy motorcycles. More weight causes the tires to stay in contact with the road and clear out water more easily.
Like the wikipedia article said, 600cc bikes are more likely to plane because they are lighter plus they have wider tyres.
So you should be encouraging him to not buy a 600. Only a 1000 or 250/125.
thanks was a 1 day course. money first then bikesales lol
Guest
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
