That is what stopped me from buying MA61 and MA70 Supra back then, read too many stories about them blowing h/gasket.
Okay just messaged my mate and he said, what you said is true.
But you just need to get the head resurfaced and possibly block, run a cosmetic steal head gasket and some arp head studs, and then it should hold well after that :thumbsup:
thinking about it.... but see below post
hardcore/cheap/lazy
Ah fair enough.
Excellent, I know something about 'yotas....
Now that is sorted.
kgo.
Need Panasports and it'll be fap-worthy.
SAU is not a vicroads authorized club for club permit scheme,
and I cannot see this changing as there is not much need considering most ppl's cars here are not more than 25 years old.
I don't think you'd ever want most people cars on club reg, too much headache.
Given its two years til r32s become eligible, now is probably a good time for SAU to sign up with only a handful of people wanting club reg, easier for the club to come up to speed with all the requirements.
I'd be worried if the gasket was cosmetic :P
Grant/Leigh - thanks
Fun riding a bike? First time?
Yea first time. They made me start on a scooter which was a waste of time but good fun. Then got me a bike, was trickier than I thought, stalled it couple times but got the hang of it by the time they started testing. Definately going for 1.5 hour courses to practise gear changing before I go out on the road.
yeah. please do. so i know if i do get one. how much i'm up for.
doing research before another potentially stupid purchase...
Normally your looking at about $2k-2.5K parts and labour including cleaning, checking and resurfacing of the head.
Though I'm sure you have chit chat with him and talk specifics I'm sure you'd be able to make a deal with him ~$1.5K for the job.
My bad... though..could go Cosmetic as they say Maybelline because you're worth it
Edited by blah_blah
Hahaha scooters are underrated. Good idea on the practice sessions, better to get these things downpat, one less thing to worry about when you get out on the road with cars. Everything becomes second nature very quickly.
hi, i have a t5 out of an xr8 that has a possible snapped input shaft.. will you still take the box? this is the only damage.. no cracks in the housing etc.... if you will would it be a lower price etc? i am in south as. can you give me a close price..?
Guest
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
