Martin that's a good point >.<
Cass your cars a 4x4 lol, lower it and watch the wheels tuck.
It's a 4x4 because it has massive front pipes...its only at that height that we managed to clear a major defect. Got done this time last year for height (70 mm clearance). Cost me 390 dollars ish to clear it. Left it to avoid further headf**ks from TMU. Will lower it again once I have the money to heat protect and tuck exhaust...but will do for now. Tucked at rears at 70mm, couldn't fit a finger between wheel and guard.
passenger door sound-deaded inside and outside, sound diffuser fitted and new splits installed woo~
Took about a month to do on/off weekends due to weather and other commitments
Drove around with no door skin for a month
Dont think i'll be able to do that with the drivers now ~_~
Especially with the window controls disconnected during this weather lawl
I forsee my sound system to be done by December at this rate haha
fix my rear speakers man! damn alternator whine!
fk yeah ric!.... 57d's are baws!
i wish i still had my orange ones :'(
although i do have a set of the blue/grey ones in 9+22 to use as track rims
Cheers man, I'm hangin for them to arrive, 6-8 weeks apparently :(
Lol'd at this. Can't really bag out on any engines until you've driven a well modded one.
i'd be more than happy to drive a 20det 32....
i just wouldn't bother looking for more than like 230rwkw
Yeah rb20det's are fine
my old 32 was up to 230rwkw on a garrett hiflow BB turbo and spool was good to, not as laggy as you would think
nice man, what sizes?
Cant wait to see them on
what part of your car was ever 70mm? the exhaust?
or are you talking the gap between fender and tyre? ;)
moh, throw inn another rb20... chuck on a 2535 or thereabouts and have ~230rwkw with a nearly 5000 rev powerband.
no engineering, no hastles, no modifications, hella fun and will cost you like $20 for the motor
this man knows what he is talking about.
rb20 - $500
hks2530 or 2535 - $700
Sard Injectors - $600
z32 afm - $150?
nistune - $300?
Tune - $200?
exhaust - $800~
boost controller - $50
$3k incl new engine for 225kw
yup, (although your prices with the "?" need to be doubled) and 230 is actually a pretty fkn quick car.
it's also a perfect ammount of power to be able to carelessly slide without having the troubles of an underpowered car, or trying to wrangle a wild bull
havent kept up with the going rates for car parts these days haha
I remember i picked up gtr injectors + z32 afm for $300 total
Just need to find someone desp for a sale.
Although wouldnt recommend gtr injectors as they leaked 1yr afterwards. Less headaches buying new and never worrying.
on another note; petrol claim for using car for business use is awesome!
75cents per km. Rack up 400km (city and back for a week) = $300 = Final inspection detail due to the cardboard box which hit my car when driving for business >_<
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
