$10,400 cover on my car with just car insur. Unfortunately it's $2000 excess lawl. $1,400pa
Whoa $1,400p.a on a $10,400 car.
Insured for about $18K and pay about $700 for full comp over here with just cars. Your area that bad lol?
Pay $300 bucks for skyline 10k if it's stolen.. Third party of course
But really insurance on an import is almost pointless especially if it's modified they could find 100 reasons not to pay out on half our cars
Yeah I got 3rd party just wanted to check how much full is. Just car has standard excess + vehicle excess + age excess. totals to $1950 excess
I'm sure I would get cheaper if I called up and used my 3rd party history with them. Was just a random online quote.
Give it a shot tony, would be interesting to see if they quote the same.
Another advantage to the third party is the significantly lower excess than you were quoted with full comp. If you have some sort of pissy love tap that hardly damages your vehicle, but leaves you with a grand of damage to the other vehicle, it won't be worth claiming under full comp, but might be under third party.
Telemarketer: Hello can I speak to the business owner
Me: Speaking...
Telemarketer: Hello sir I am from Telstra, the reason I am calling is because I want to save you money on your monthly phone account
Me: I don't have a phone
Telemarketer: *silence*
Telemarketer: How am I speaking with you right now?
Me: GET OUT OF MY HEAD
No that's because you sent me a message while I was watching Falling Down, and no one interupts me while I'm watching that. Then I forgot about it. I'm away this weekend, if you can wait til Friday week we'll head to CQ?
Aren't u like 30 already? ;)
Car booked in for turbo install...could not be assed attempting it and dealing with broken manifold studs at the same time. Here comes the sun, little darlin'
For sure, it's been too long. Good chance to build some more rapport in the meantime
Who you gettin to do turbo install? Rob?
OTR...they've done a couple of HG turbos and work on Tao's car so should be familiar with fittings etc.
Then I'll drive it to RevZone for some tuning.
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
