http://m.theage.com.au/national/noisy-cars-most-annoying-20120221-1tlqi.html
Didn't go Tony they usually exaggerate heaps so id be doubful of 220 I went to one they were like 120 cars was about 70 they just park like idiots so looks more packed lol
Edited by alr33x
17 inch meisters on a 33gts. too small?
not if they are fitted well... 17's are baws
Would vodafone pay out my optus contract if I switch with them?
i'm guessing no
lol what's he saying?
I was thinking more along the lines of police attention...the bigger you are the more you get noticed. It's a shame because seeing pictures like these reminds me of the good old days, and good to import spirit alive and well...won't be long before the police make their mark on them though.
Still laugh at the time I was clubbing with Birds and Flynnn tried to pay for entry with a large ziplock bag of silver coins lol
lol, the shit Maree had to pull to get him inside...not sure if trolling door girl or serious?
Your joking right?
$15/$20 cover charge paid in silver coins...?
17 meisters will look gay.. i think my 18 meisters look gay to be honest..
they would look good in chrome
so we can conclude that meisters look gay?
Nah, WORK Meisters S1 look good, Aarons just trolling gay.
I'm looking at them right now and, yeah, pretty gay.
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
