Dude. Just accept the fact cheezetv isnt on anymore.
lol nice. only good call I've heard from you.
I see your using Arnie's trick of sleeping faster
Well played mohomo
trick? lol i just dont sleep
Ayo...if you want to lose a gut, gym is the wrong way about it...it will help, but you got to start sweating. Run.
yeh as others said Im allergic to that shit..todays my off day so I might go for a run and see what comes out of it.. was also thinking of buying a bike.
Alvin, just grab some extinsurger from supercheap auto and bolt the brackets on where nuts for the seats go.
Blue sticker, put it pointing where battery is.
EDIT; tow stickers, eBay or revolution racegear.
This man knows.
Cept I'm allergic to cardio.
I'll get around to it one day.
Go for a run tonight.
lol I told him eBay and RR too...
Questions now. Fire extinguiser. How big? where do i get mounting brackets. where do i mount them?
Stickers, that blue triangle goes over the bonnet where the battery is yea?
The TOW triangles, where do i get them?
i have some angel ally between passanger seat bolts and drilled holes and pop riveted bracket to it seat even slides over the top .i have some ally if you want it
blue and red contact from news agent = win. All of $5ea for a roll of 5M, that is a lot of triangles.
fire ext easy to do with a bit a metal from bunnings, plus something to cut it with and something to drill holes with.
got no drill and no cutting tools. LOL =(
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
