Vic Wasteland Thread
R31Nismoid
on a long weekend with good weather it is
all the bikes and quick cars go thinking its going to be empty and an awesome run
but it would probably be full of slow std cars and cops trying to catch out hoons
Yeah not really expecting the roads to be empty.
So for anyone thats interested:
Meet Point: Macca's cnr of Springvale Road and Maroondah Hwy:
Time: 9:40 meet for 10am departure.
Destination: Via black spur, either going to the famous buxton burgers at the igloo or parmas up at Alexandra.
Intradasting....
May need to think of a plan B...
Yep tony, like you suggested, PLAN B!!
Still meet at the maccas on springvale rd and maroondah hwy for a 10am departure.
Pull out your map....
Take maroondah hwy down to lilydale. Turn off towards seville/ yarra junction/ warburton then head up to buxton/ alexander
Guys does anyone know much about meth kits? Methanol injection kits, connected to FMIC etc.
Need knowledge input if so.
You started your own firm or something brah? When are you hiring me?
Haha. It is in the pipeline actually, but looking at another 12 months minimum. :).
Very busy with other stuff atm.
do NOT connect it before the intercooler
only after and just before throttle body
ensure your ECU can detect if there is no meth and use alternate timing or adjust accordingly
i think it should be wired in via a pressure switch so it only comes on when boost exceeds a minimal level ie 6psi
so that it doesnt run meth when your on light cruise etc
also think it should be wired in like NOS, via the TPS, when TPS is 100% fire the meth solenoid
I have no idea about it. I have a meth kit, as it came as part of a tuning kit for my car. The ECU in my car does have a 'meth' map.
i purchased a kit but never got around to installing it.
http://www.aquamist.co.uk/vbulletin/showthread.php?t=2158
I might have the same kit or similar. But mine says something about mixing water and meth in the window washer bottle.
Too much confusion.
Anyone actually installed one or know of someone who has?
Also, where to get the right meth from?
Cheers.
Guest
    • Time for millspec wiring, MoTec electronics package, Bosch Motorsport ABS, let's goooooooo!!!   Maybe as @MBS206 suggested, just swap out those stupid blue relays near the ECU plug.
    • My only regret with the NC MX5 was no space for a spare, even a space saver doesn't fit in I do have a couple of those puncture repair spray cans, but if I get a large puncture, or sidewall damage, I'm screwed until a tilt tray turns up I'm thinking I might get one of those 4WD style of puncture repair kits that have that rope stuff and glue, whilst it will kill any hope of saving a tyre, it might help getting me out from some backwoods road far enough to find a actual tyre shop if the first can of tyre fix doesn't work I'm keen to see how your new toy pans out Uncle Duncan, I'll be moving to the Highlands next year, you'll need to shout out if your heading to Wakefield, whilst I've lost my balls for happy laps, I still love watching those that can
    • Yeah not sure what the warranty was, but it will be years outside it.  I've shot Link a message, will see what happens, I'm told their support is good. It is a plug in, so its a Link board in a factory case, very easy to access both sides of the circuit board by removing the top or bottom cover. To be fair the the Link, although I've checked to the factory connections and wiring specs, as we learned with Neil's car in the early days not all ECUs source power the same way. He'd been running a factory ECU with no trouble for years, but when we plugged a PowerFC in it wouldn't start up, just kept cycling power on and off. We worked out that the car was missing one of the 10a fuses "Electronic Parts", and to Neil's knowledge it had never been there. Turns out the ECU pulled its main power from that source not the same place the factory ECU did.  Point being....there are multiple battery and ECCS power sources in the factory ECU, and multiple grounds as well....not telling from the outside exactly what the Link uses (and doesn't use)
    • Now, thanks to sonicii, onto the uneven floor from a tyre sticking 100mm into the boot space. I looked into options to raise the floor to the level of the tyre, and ended up going Extruded Polystyrene (XPS). EPS is what I normally think of as polystyrene, the annoying tiny balls that get glued into a flat sheet but XPS is quite different, much firmer and doesn't crumble if you touch it with anything. I also looked at things like heavy duty seating foam but XPS seemed like the right way. I picked up 3x 1200x600x50 sheets for $40ea. Initially I was looking for 100mm sheets because I needed to make up a 100mm gap, but as it turned out 50mm was available, much easier to work with and made it simple to store the tools I used a simple 15cm foam cutter to make the shapes. With some practice I was able to make reasonably clean cuts but I don't think Clark Rubber are going to be calling me to offer a job. https://www.ebay.com.au/itm/405092315205?var=675175481574 First layer in place, 3 dimensions are tricky! Second layer in place, bringing it to level with the top of the spare Cutouts in the top layer for the tools With floor back in place, nice and flat with 100mm stolen but no real impact on usability
    • Sounds like a good idea to me moh
