I have no idea about it. I have a meth kit, as it came as part of a tuning kit for my car. The ECU in my car does have a 'meth' map.
I might have the same kit or similar. But mine says something about mixing water and meth in the window washer bottle.
Too much confusion.
Anyone actually installed one or know of someone who has?
Also, where to get the right meth from?
Cheers.
hmm sounds a bit risky to play with it when you dont know the history of it. The idea is to blend 50:50 water and methanol and add to the container which the system is connected to. Normal setups come with a dedicated tank and do not use the window washer bottle. Depends if the previous owner did a dodgy or removed the system?
You will need to find a supplier of methanol (methylated spirits is ethanol with a bit of methanol put in to stop people drinking it, so that wont work)
Most race fuel suppliers can supply methanol in 20Ltr or drums etc
Methonal is very dangerous and you dont want to smell/touch it etc. An option is to run just 100% water instead. That will reduce the air temperature but will not give more octane (methanol is like 120ron). A blend gets the best of water and methanol but having 100% water is easier to manage.
Apparently neither does the meth...guy at work reckons that when he had his own detailing business, one of his employees used to toss back a bottle of methylated spirits at lunch time...you know you have a problem when your alcohol doesn't even come from the liquor store.
oh man thats so bad haha
Nitro-meth is another level. Instead of using water-meth blend, you do a water-nitrometh blend. Moar powar
I refuse to jack off with anything but glitter lotion
Tuesday morning lulz
What did everyone do this long weekend?
I went on a 3 day bender.....
I think my heart stopped beating a couple times..
Helped a mate buy a s13 shell. Went to parents holiday house and fishing.... I've never really liked fishing, this time was different, it was good to just stand there pondering things. Fishing is kinda like extended shower time, Just stand there thinking about things.
Guest
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
