Grant - i didnt quite get your meaning but youre concerned re front plate fitting in the recess?
short answer, it doesnt....
i have my plates (both standard at first and now the custom plates) bolted into the front bar using what are like rubber extenders i guess...circular black rubber supports that come out from the recess in the front bar and hold the plate on with bolts into it. i didnt put them there though so i dunno where youd get them from...
I used rubber tap washers from Bunnings for that.
i couldnt see anywhere in the rules that said i couldnt :P
It's called the divine power... Or commmonly known as discretion :P
Treat all members with respect and courtesy - We will ban any member(s) who make personal attacks, threats or mistreats any other member in anyway (discretion is up to the moderator at the time of the offence)
curse that word discretion if it wasnt in that sentence scotty would have known.
but deep down you lol'd at that pic :P
Guest
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
